DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement
Views: 135K
View statistics:
Past 24 Hours:
47
Past 7 Days:
250
Past 30 Days:
1,248
All Time:
134,916
Comments: 16
14 comments on steps, 2 guide comments.
Go to guide comments
Completed: 51
51 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace the R2 and L2 Buttons in your DualShock 4 model CUH-ZCT1U controller.
Parts
Tools
    1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Check your controller model: step 1, image 1 of 1
      • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
      • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the rear case: step 2, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the rear case: step 2, image 2 of 2
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
      • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: step 3, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: step 3, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L1 button: step 3, image 3 of 3
      • Use an opening pick to pry each corner of the L1 button from the front case.
      • Cover the button to prevent it from ejecting out of your workspace.
      • Remove the button.
      Ask FixBot
    4. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R1 button: step 4, image 1 of 1
      • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
      Ask FixBot
    5. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: step 5, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: step 5, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unclip the rear case: step 5, image 3 of 3
      • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
      • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
      • Slide your pick toward the handle and pry up to release the first clip.
      • Repeat this procedure on the other side of the controller to release the second clip.
      Ask FixBot
    6. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 6, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 6, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 6, image 3 of 3
      • Two more clips secure the rear case near the extension port and the headphone jack.
      • Insert your opening pick between the front case and rear case at either side of the ports.
      • Twist your pick to unclip this section of the rear case from the front case.
      • If the rear case feels stuck, insert and twist your pick from different angles.
      • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
      Ask FixBot
    7. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 7, image 1 of 1
      • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
      • Locate the clips by looking through the gap above the R2 or L2 buttons.
      Ask FixBot
    8. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 8, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 8, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 8, image 3 of 3
      • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
      • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
      • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
      • Repeat this procedure for the clip near the L2 button.
      Ask FixBot
    9. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: step 9, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: step 9, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the rear case: step 9, image 3 of 3
      • Press the R2 button and slide the rear case over it.
      Ask FixBot
    10. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 10, image 1 of 1
      • Press the L2 button and slide the rear case over it.
      Ask FixBot
    11. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 11, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 11, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 11, image 3 of 3
      • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
      Ask FixBot
    12. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: step 12, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: step 12, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the interconnect cable: step 12, image 3 of 3
      Buy
      • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
      • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the battery: step 13, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the battery: step 13, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
      • Only pull on the head of the connector—don't pull on the cable itself.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery: step 14, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the reset button extension: step 15, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the reset button extension: step 15, image 2 of 2
      • Grab and remove the reset button extension from its recess in the battery bracket.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: step 16, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: step 16, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the battery bracket: step 16, image 3 of 3
      • Locate the two clips securing the battery bracket to the motherboard.
      • Insert the point of your spudger into the opening behind the right bracket clip.
      • Depress the clip to disengage it from the motherboard.
      • Lift up the right edge of the battery bracket.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 17, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 17, image 2 of 2
      • Insert the point of your spudger in the opening behind the left bracket clip.
      • Remove the battery bracket.
      Ask FixBot
    4. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: step 18, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: step 18, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Disconnect the touch pad: step 18, image 3 of 3
      Buy
      • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
      • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Unfasten the motherboard: step 19, image 1 of 1
      • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
      • During reassembly, hold the motherboard tight to the front case before fastening it. Test each button to ensure the silicone button pads are properly aligned. If each button presses as expected, fasten the motherboard.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the midframe: step 20, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the midframe: step 20, image 2 of 2
      • Grab the midframe by its plastic protrusions or the vibration motors and remove it.
      • Be careful not to separate the motherboard from the midframe, as they're only connected to each other by the vibration motor cables.
      • During reassembly, take your time positioning the midframe. Use the alignment posts to help guide it into place, and make sure the touch pad cable doesn't become trapped underneath.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the motherboard: step 21, image 1 of 2 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the motherboard: step 21, image 2 of 2
      • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
      • Lift the motherboard and flip it over the bottom of the midframe, leaving the vibration motor cables attached.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: step 22, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: step 22, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the R2 button: step 22, image 3 of 3
      • Firmly grip the R2 button and unclip each peg from the midframe.
      • The spring may eject from the inside peg. Be careful not to lose it.
      • Remove the R2 button.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the L2 button: step 23, image 1 of 1
      • Unclip the L2 button from the midframe and remove it, making sure not to lose the small spring from the inside peg.
      Ask FixBot
    4. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: step 24, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: step 24, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Reassembly information: step 24, image 3 of 3
      • During reassembly, follow these instructions to install the springs onto the R2 and L2 buttons:
      • Lay the midframe face-down and orient the button properly.
      • Place the spring over the inside peg with its bent ends facing upward.
      • Rest one end of the spring in its channel in the button.
      • Place the button over its clips and rest the other end of the spring in its channel in the midframe.
      • Press the button's pegs into their clips until they snap into place.
      Ask FixBot
    5. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: step 25, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: step 25, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement, Remove the silicone button pads: step 25, image 3 of 3
      • Grab the upper edge of the R1 and R2 button pad.
      • Slide the pad out of its channel in the midframe.
      Ask FixBot
    6. DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 26, image 1 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 26, image 2 of 3 DualShock 4 (CUH-ZCT1U) R2 and L2 Buttons Replacement: step 26, image 3 of 3
      • Slide the L1 and L2 button pad out of its channel in the midframe and remove it.
      • Each pad has two plugs and an upper groove to align it with the midframe. During reassembly, ensure the plugs are inserted in their holes and the groove is hooked onto the tab in the midframe.
      Ask FixBot
51 other people completed this guide.
Clay Eickemeyer
108,082 Reputation
471 Guides authored
2 Guide Comments
Rimettere quella piccola molla è praticamente impossibile 😭
Clash Royale - Reply Share
ma scusate perché disassemlare tutto il pad?
rain naxiil - Reply Share
Past 24 Hours: 47
Past 7 Days: 250
Past 30 Days: 1,248
All Time: 134,916
