DualShock 4 (CUH-ZCT1U) Buttons Replacement
    1. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Check your controller model: step 1, image 1 of 1
      • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
      • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unfasten the rear case: step 2, image 1 of 2 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unfasten the rear case: step 2, image 2 of 2
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
      • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the L1 button: step 3, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the L1 button: step 3, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the L1 button: step 3, image 3 of 3
      • Use an opening pick to pry each corner of the L1 button from the front case.
      • Cover the button to prevent it from ejecting out of your workspace.
      • Remove the button.
      Ask FixBot
    4. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the R1 button: step 4, image 1 of 1
      • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
      Ask FixBot
    5. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unclip the rear case: step 5, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unclip the rear case: step 5, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unclip the rear case: step 5, image 3 of 3
      • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
      • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
      • Slide your pick toward the handle and pry up to release the first clip.
      • Repeat this procedure on the other side of the controller to release the second clip.
      Ask FixBot
    6. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 6, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 6, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 6, image 3 of 3
      • Two more clips secure the rear case near the extension port and the headphone jack.
      • Insert your opening pick between the front case and rear case at either side of the ports.
      • Twist your pick to unclip this section of the rear case from the front case.
      • If the rear case feels stuck, insert and twist your pick from different angles.
      • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
      Ask FixBot
    7. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 7, image 1 of 1
      • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
      • Locate the clips by looking through the gap above the R2 or L2 buttons.
      Ask FixBot
    8. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 8, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 8, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 8, image 3 of 3
      • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
      • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
      • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
      • Repeat this procedure for the clip near the L2 button.
      Ask FixBot
    9. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the rear case: step 9, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the rear case: step 9, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the rear case: step 9, image 3 of 3
      • Press the R2 button and slide the rear case over it.
      Ask FixBot
    10. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 10, image 1 of 1
      • Press the L2 button and slide the rear case over it.
      Ask FixBot
    11. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 11, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 11, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 11, image 3 of 3
      • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
      Ask FixBot
    12. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the interconnect cable: step 12, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the interconnect cable: step 12, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the interconnect cable: step 12, image 3 of 3
      Buy
      • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
      • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the battery: step 13, image 1 of 2 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the battery: step 13, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
      • Only pull on the head of the connector—don't pull on the cable itself.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the battery: step 14, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the reset button extension: step 15, image 1 of 2 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the reset button extension: step 15, image 2 of 2
      • Grab and remove the reset button extension from its recess in the battery bracket.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the battery bracket: step 16, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the battery bracket: step 16, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the battery bracket: step 16, image 3 of 3
      • Locate the two clips securing the battery bracket to the motherboard.
      • Insert the point of your spudger into the opening behind the right bracket clip.
      • Depress the clip to disengage it from the motherboard.
      • Lift up the right edge of the battery bracket.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 17, image 1 of 2 DualShock 4 (CUH-ZCT1U) Buttons Replacement: step 17, image 2 of 2
      • Insert the point of your spudger in the opening behind the left bracket clip.
      • Remove the battery bracket.
      Ask FixBot
    4. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the touch pad: step 18, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the touch pad: step 18, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Disconnect the touch pad: step 18, image 3 of 3
      Buy
      • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
      • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Unfasten the motherboard: step 19, image 1 of 1
      • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
      • During reassembly, hold the motherboard tight to the front case before fastening it. Test each button to ensure the silicone button pads are properly aligned. If each button presses as expected, fasten the motherboard.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the midframe: step 20, image 1 of 2 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the midframe: step 20, image 2 of 2
      • Grab the midframe by its plastic protrusions or the vibration motors and remove it.
      • Be careful not to separate the motherboard from the midframe, as they're only connected to each other by the vibration motor cables.
      • During reassembly, take your time positioning the midframe. Use the alignment posts to help guide it into place, and make sure the touch pad cable doesn't become trapped underneath.
      Ask FixBot
    1. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the Share and Options buttons: step 21, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the Share and Options buttons: step 21, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the Share and Options buttons: step 21, image 3 of 3
      • Remove the Share and Options buttons from the front case.
      • During reassembly, there's only one way for each button to insert. If one doesn't fit, flip it and try the other recess.
      Ask FixBot
    2. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the silicone button pads: step 22, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the silicone button pads: step 22, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the silicone button pads: step 22, image 3 of 3
      • Remove the three silicone button pads from their buttons in the front case:
      • The squared off pad for the directional pad
      • The rounded pad for the action buttons
      • The small pad for the home button
      • If you wish to remove the silicone button pads for the touch pad, Share, and Options buttons, follow this step. Otherwise, continue for the standard set of buttons.
      • During reassembly, align the pads over their cutouts in the front case and apply pressure to secure them. The directional pad and action button pad can be rotated in any direction. Orient the home button pad with the opening of the U-shaped cutout facing the touch pad.
      Ask FixBot
    3. DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the remaining buttons: step 23, image 1 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the remaining buttons: step 23, image 2 of 3 DualShock 4 (CUH-ZCT1U) Buttons Replacement, Remove the remaining buttons: step 23, image 3 of 3
      • Remove the directional pad, action buttons, and home button from the front case.
      • During reassembly, use the alignment tabs to orient each button into its recess. Each one is keyed specifically for its recess and proper orientation.
      Ask FixBot
131 other people completed this guide.
Clay Eickemeyer
107,088 Reputation
472 Guides authored
23 Guide Comments
I pulled out my touch pad along with the motherboard when it was still attached how can I put this back in
Landen Nipper - Reply Share
Pull out the ribbon the way the tutorial says and then you can place the touchpad back correctly. It needs to be put in from the inside of the controller, not the outside.
Luis Rodriguez - Reply Share
where is how replace L2/R2? D=
ps4 - Reply Share
This guide could be enhanced by showing the L1/L2, R1/R2 button cluster in some photos. I needed to replace the silicone grommet underneath the buttons due to Sony's design flaw of having R2/L2 press on the silicone with a blade shaped extension.
Joseph Bruni - Reply Share
What to do If after cleaning some buttons no longer work? I was very careful when disassembling and reassembling the remote.
Amanda G Clark - Reply Share
Past 24 Hours: 40
Past 7 Days: 234
Past 30 Days: 1,247
All Time: 293,279
