DualSense Controller V5 Microphone Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
8
Past 7 Days:
52
Past 30 Days:
193
All Time:
1,823
Comments: 24
24 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the microphones (upper and lower) in your Sony PlayStation DualSense V5 controller.
If your controller has a hard time picking up your voice, or has intermittent issues, the microphones may need to be replaced.
If you only want to replace the lower microphone, stop at this step. Otherwise, follow the guide to the end to replace the upper microphone.
Tools
    1. DualSense Controller V5 Microphone Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller V5 Microphone Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller V5 Microphone Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller V5 Microphone Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller V5 Microphone Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller V5 Microphone Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller V5 Microphone Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller V5 Microphone Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller V5 Microphone Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Controller V5 Microphone Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Controller V5 Microphone Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Controller V5 Microphone Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Controller V5 Microphone Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Remove the rear case screws: step 8, image 1 of 2 DualSense Controller V5 Microphone Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement: step 9, image 1 of 2 DualSense Controller V5 Microphone Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Controller V5 Microphone Replacement, Separate the rear case: step 10, image 1 of 3 DualSense Controller V5 Microphone Replacement, Separate the rear case: step 10, image 2 of 3 DualSense Controller V5 Microphone Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Controller V5 Microphone Replacement: step 11, image 1 of 3 DualSense Controller V5 Microphone Replacement: step 11, image 2 of 3 DualSense Controller V5 Microphone Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. DualSense Controller V5 Microphone Replacement: step 12, image 1 of 3 DualSense Controller V5 Microphone Replacement: step 12, image 2 of 3 DualSense Controller V5 Microphone Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. DualSense Controller V5 Microphone Replacement: step 13, image 1 of 2 DualSense Controller V5 Microphone Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Disconnect the battery: step 15, image 1 of 2 DualSense Controller V5 Microphone Replacement, Disconnect the battery: step 15, image 2 of 2
      • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
      • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
      • Keep the battery supported so it doesn't fall during the next step.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement: step 16, image 1 of 3 DualSense Controller V5 Microphone Replacement: step 16, image 2 of 3 DualSense Controller V5 Microphone Replacement: step 16, image 3 of 3
      • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
      • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
      • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
      Ask FixBot
    3. DualSense Controller V5 Microphone Replacement, Remove the battery: step 17, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Remove the lower microphone: step 18, image 1 of 2 DualSense Controller V5 Microphone Replacement, Remove the lower microphone: step 18, image 2 of 2
      • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
      • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement, Remove the battery bracket: step 19, image 1 of 2 DualSense Controller V5 Microphone Replacement, Remove the battery bracket: step 19, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
      Ask FixBot
    3. DualSense Controller V5 Microphone Replacement: step 20, image 1 of 2 DualSense Controller V5 Microphone Replacement: step 20, image 2 of 2
      • Remove the battery bracket.
      Ask FixBot
    4. DualSense Controller V5 Microphone Replacement, Disconnect the motherboard: step 21, image 1 of 2 DualSense Controller V5 Microphone Replacement, Disconnect the motherboard: step 21, image 2 of 2
      • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
      • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
      Ask FixBot
    5. DualSense Controller V5 Microphone Replacement: step 22, image 1 of 3 DualSense Controller V5 Microphone Replacement: step 22, image 2 of 3 DualSense Controller V5 Microphone Replacement: step 22, image 3 of 3
      Ask FixBot
    6. DualSense Controller V5 Microphone Replacement, Reposition the motherboard: step 23, image 1 of 2 DualSense Controller V5 Microphone Replacement, Reposition the motherboard: step 23, image 2 of 2
      • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
      • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
      Ask FixBot
    7. DualSense Controller V5 Microphone Replacement: step 24, image 1 of 2 DualSense Controller V5 Microphone Replacement: step 24, image 2 of 2
      • Carefully flip the motherboard down so the joysticks are facing up.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Speaker note: step 25, image 1 of 2 DualSense Controller V5 Microphone Replacement, Speaker note: step 25, image 2 of 2
      • The speaker may have fallen out when repositioning the motherboard. If it did, set it aside for reassembly. If it stayed in place on the motherboard or is in its recess in the front case, you can leave it in place.
      • During reassembly, place the speaker in its recess so the foam pad is on the left and the spring contacts are on the right.
      Ask FixBot
    1. DualSense Controller V5 Microphone Replacement, Flip the controller over: step 26, image 1 of 2 DualSense Controller V5 Microphone Replacement, Flip the controller over: step 26, image 2 of 2
      • Grip the controller in one hand and motherboard in the other and carefully flip them over.
      Ask FixBot
    2. DualSense Controller V5 Microphone Replacement, Remove the upper microphone: step 27, image 1 of 2 DualSense Controller V5 Microphone Replacement, Remove the upper microphone: step 27, image 2 of 2
      • Use tweezers to remove the upper microphone, threading its cable through the cutout in the case.
      Ask FixBot
Spencer Day
207,749 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 193
All Time: 1,823
