DualSense Controller V5 Battery Replacement
Views: 7K
View statistics:
Past 24 Hours:
23
Past 7 Days:
154
Past 30 Days:
520
All Time:
6,951
Comments: 22
22 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace the battery in your Sony PlayStation DualSense V5 controller.
If your battery is swollen, take appropriate precautions.
Tools
    1. DualSense Controller V5 Battery Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller V5 Battery Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller V5 Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller V5 Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller V5 Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller V5 Battery Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller V5 Battery Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller V5 Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller V5 Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller V5 Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller V5 Battery Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller V5 Battery Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller V5 Battery Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. DualSense Controller V5 Battery Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Controller V5 Battery Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Controller V5 Battery Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. DualSense Controller V5 Battery Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Controller V5 Battery Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Controller V5 Battery Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. DualSense Controller V5 Battery Replacement, Remove the rear case screws: step 8, image 1 of 2 DualSense Controller V5 Battery Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Controller V5 Battery Replacement: step 9, image 1 of 2 DualSense Controller V5 Battery Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Controller V5 Battery Replacement, Separate the rear case: step 10, image 1 of 3 DualSense Controller V5 Battery Replacement, Separate the rear case: step 10, image 2 of 3 DualSense Controller V5 Battery Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Controller V5 Battery Replacement: step 11, image 1 of 3 DualSense Controller V5 Battery Replacement: step 11, image 2 of 3 DualSense Controller V5 Battery Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. DualSense Controller V5 Battery Replacement: step 12, image 1 of 3 DualSense Controller V5 Battery Replacement: step 12, image 2 of 3 DualSense Controller V5 Battery Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. DualSense Controller V5 Battery Replacement: step 13, image 1 of 2 DualSense Controller V5 Battery Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. DualSense Controller V5 Battery Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. DualSense Controller V5 Battery Replacement, Disconnect the battery: step 15, image 1 of 2 DualSense Controller V5 Battery Replacement, Disconnect the battery: step 15, image 2 of 2
      • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
      • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
      • Keep the battery supported so it doesn't fall during the next step.
      Ask FixBot
    2. DualSense Controller V5 Battery Replacement: step 16, image 1 of 3 DualSense Controller V5 Battery Replacement: step 16, image 2 of 3 DualSense Controller V5 Battery Replacement: step 16, image 3 of 3
      • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
      • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
      • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
      Ask FixBot
    3. DualSense Controller V5 Battery Replacement, Remove the battery: step 17, image 1 of 1
      • Remove the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
7 other people completed this guide.
Spencer Day
208,184 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
0 Guide Comments
Past 24 Hours: 23
Past 7 Days: 154
Past 30 Days: 520
All Time: 6,951
