Shop the Holiday Gift Guide
Repairing Patagonia Jacket with a Shaped Baffle
Views: 21K
View statistics:
Past 24 Hours:
9
Past 7 Days:
76
Past 30 Days:
225
All Time:
20,937
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
This guide will show you how to patch a shaped baffle on your Nano Puff ® Jacket. The baffle we’ll be repairing in this guide is a rectangle, but the process is the same for any shape. In this guide we’ll show you how to patch the baffle without deconstructing the garment. This means that the repair stitching will show through on the jacket lining. If you’d rather not have the stitching visible, check out our Opening a Jacket Guide, and go through those steps first, before you follow the steps in this guide. (Opening the jacket makes this repair more difficult and time consuming). If you choose matching thread, your repair thread in the lining should hardly be noticible, but the choice is yours. New to sewing? Check out our sewing glossary.
For replacement parts or further assistance, contact Patagonia Customer Service.
Return to the Patagonia Care & Repair homepage.
    1. Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle, Repairing Patagonia Jacket with a Shaped Baffle: step 1, image 3 of 3
      • Examine the damage on your jacket, cutting off any loose threads and freeing any debris
      • Our garment has holes in two of the baffle segments, but we will just work on one for this guide.
      • Choose some patch fabric.
      • Why not choose a fun color? We did.
      • Select thread that matches your patch fabric, and load it into your sewing machine.
      • Select thread that matches the lining of your jacket, and load it into the bobbin of your sewing machine.
      Ask FixBot
    2. Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 2, image 3 of 3
      • Trace the shape of your baffle onto some cardstock or heavy paper.
      • Cut out the shape of the baffle; this will be your template.
      • Place the template over the baffle to ensure that the shape and size of your template is correct.
      Ask FixBot
    3. Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 3, image 3 of 3
      • Set your iron to the appropriate setting—in our case, nylon—and iron your patch fabric to smooth out any wrinkles.
      • Position the template on the patch fabric, leaving about ¼ or ½ inch of extra fabric around the edges.
      • Cut out the patch, leaving 1/4 or 1/2 inch of extra fabric around each side of the template.
      Ask FixBot
    4. Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 4, image 3 of 3
      • Fold the edge of the fabric over, creating a fold at the edge of the template.
      • Carefully hold the fabric in place and iron it down.
      Ask FixBot
    5. Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 5, image 3 of 3
      • Work around the template, folding each side in, and ironing it into place.
      Ask FixBot
    6. Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 6, image 3 of 3
      • Slide the template out of the patch.
      • Refold along the creases you previously ironed.
      • Turn the patch over so that the right-side, or the side that will be showing, is up and press it.
      Ask FixBot
    7. Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 7, image 3 of 3
      • Align the patch with the baffle, exactly as you want it to appear when you are done.
      • Slide the garment into the sewing machine, repositioning the patch if necessary.
      • To prevent the insulation from leaking through the stitches, fit your sewing machine with the smallest needle available.
      • Sink the needle to hold the patch into place.
      • Do not pin the patch, as this will create unnecessary holes where down can escape.
      • Holding the patch in place sew directly over the edge of your patch.
      Ask FixBot
    8. Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 8, image 3 of 3
      • When you come to the corner of your patch, sink the needle.
      • Lift the presser foot, leaving the needle in the fabric, and gently turn the fabric 90 degrees, aligning it with the edge of the patch.
      • Drop the presser foot and continue sewing along the second edge of the patch.
      • Be sure to hold the patch in place as you sew.
      Ask FixBot
    9. Repairing Patagonia Jacket with a Shaped Baffle: step 9, image 1 of 2 Repairing Patagonia Jacket with a Shaped Baffle: step 9, image 2 of 2
      • As you did with the first corner, sink the needle, lift the presser foot, and rotate the garment.
      • Drop the presser foot and continue sewing on the third edge of the patch.
      Ask FixBot
    10. Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 10, image 3 of 3
      • Repeat step nine for the last corner, and sew the final edge of the patch in place.
      • Backstitch when you come to the end of the patch.
      Ask FixBot
    11. Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 1 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 2 of 3 Repairing Patagonia Jacket with a Shaped Baffle: step 11, image 3 of 3
      • Lift the needle and presser foot, freeing the garment from the sewing machine.
      • Clip any threads, and admire your work!
      Ask FixBot
Finish Line
7 other people completed this guide.
Author
with
Brittany McCrigler
91,182 Reputation
142 Guides authored
1 Guide Comment
hello, I hope this finds you well.
Can I buy repair fabric from Patagonia? My jacket seems to attract rips. And the local tailor does a fast and good job.
Thanks!
Andrew
Andrew Chepaitis - Reply Share
Past 24 Hours: 9
Past 7 Days: 76
Past 30 Days: 225
All Time: 20,937
