Screen Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Screen Removal, Unfasten the display brackets: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
    • Four 1.1 mm-long screws
    • Two 2.0 mm-long screws
    • One 1.0 mm-long screw
  2. Screen Removal, Remove the display brackets: step 2, image 1 of 3 Screen Removal, Remove the display brackets: step 2, image 2 of 3 Screen Removal, Remove the display brackets: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers, or your fingers, to remove the top and bottom display brackets.
  3. Screen Removal, Disconnect the bottom display cables: step 3, image 1 of 3 Screen Removal, Disconnect the bottom display cables: step 3, image 2 of 3 Screen Removal, Disconnect the bottom display cables: step 3, image 3 of 3
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  4. Screen Removal, Disconnect the top display cables: step 4, image 1 of 3 Screen Removal, Disconnect the top display cables: step 4, image 2 of 3 Screen Removal, Disconnect the top display cables: step 4, image 3 of 3
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  5. Screen Removal, Remove the screen: step 5, image 1 of 3 Screen Removal, Remove the screen: step 5, image 2 of 3 Screen Removal, Remove the screen: step 5, image 3 of 3
    • Remove the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Alex Diaz-Kokaisl
216,464 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,895 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 61
