Introduction
This guide demonstrates how to disassemble the G700 mouse in order to reach the top mouse buttons for cleaning.
The mouse will be broken down into three main components: The circuit board, top housing, and middle housing.
Unplug the USB cord from the top of the mouse.
Power off the mouse. The power switch is located on the bottom of the mouse above the battery.
Peel off the four sticker pads located on the bottom of the mouse. They will be on the top, bottom and sides.
Stick these pads onto a clean, flat surface for safe keeping as you continue to disassemble the mouse.
Press the side keys toward the bottom of the housing.
This will detach the keys and wires from the housing.
Gently pry away the upper part of the housing.
View: Housing divided into two pieces: top and middle
Unscrew the two screws holding the part that locks the function buttons.
View: Underneath middle housing
Carefully pull each button towards you.
Do not misplace the small springs attached to the buttons.
