Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons
  1. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 2, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 2, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 2, image 3 of 3
    • Power off the mouse. The power switch is located on the bottom of the mouse above the battery.
  2. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 3, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 3, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 3, image 3 of 3
    • Remove the battery as illustrated in the images.
  3. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 4, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 4, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 4, image 3 of 3
    • Peel off the four sticker pads located on the bottom of the mouse. They will be on the top, bottom and sides.
    • Stick these pads onto a clean, flat surface for safe keeping as you continue to disassemble the mouse.
  4. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 5, image 1 of 2 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 5, image 2 of 2
    • Locate and remove the five screws that were hidden under the sticker pads.
  5. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 6, image 1 of 2 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 6, image 2 of 2
    • Carefully pry off the top of the mouse. This will remove the housing from the circuit board.
  6. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 7, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 7, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 7, image 3 of 3
    • Gently detach the four wires from the holder of the housing.
    • View: Underneath housing
  7. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 8, image 1 of 2 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 8, image 2 of 2
    • Remove the seven screws that hold the top housing, middle housing, and side keys together.
    • If disassembling for cleaning purposes, you need only to remove the four screws near the bottom in order to remove the top cover alone.
  8. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 9, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 9, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 9, image 3 of 3
    • Press the side keys toward the bottom of the housing.
    • This will detach the keys and wires from the housing.
  9. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 10, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 10, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 10, image 3 of 3
    • Gently pry the lock holding both mouse buttons.
    • View: Underneath housing (still one piece)
  10. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 11, image 1 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 11, image 2 of 3 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 11, image 3 of 3
    • Gently pry away the upper part of the housing.
    • View: Housing divided into two pieces: top and middle
  11. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 12, image 1 of 1
    • Unscrew the two screws holding the part that locks the function buttons.
    • View: Underneath middle housing
  12. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 13, image 1 of 2 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 13, image 2 of 2
    • Slowly remove the plastic part you just unscrewed.
  13. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 14, image 1 of 1
    • Carefully pull each button towards you.
    • Do not misplace the small springs attached to the buttons.
  14. Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 15, image 1 of 2 Disassembling Logitech Wireless Gaming Mouse G700 Mouse Buttons: step 15, image 2 of 2
    • Congratulations! You are now able to clean the mouse.
    • Be careful when reinstalling the screws. Due to their small size, they strip the sockets easily if overtightened.
Tomasz
879 Reputation
1 Guide authored
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 146
All Time: 49,926
