Introduction
The following guide will help with the safe disassembly of the casing and the two separate the sides of the device. Follow each step carefully as to not damage the device.
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two screws with a Phillips #0 screwdriver.
Slowly remove the center band and two clip rings until the adhesive separates.
Use the spudger to pry the device apart along its seam, starting in the middle.
Open the device to separate the front and back panels.
Remove the speaker wire (yellow, red, black, white) from the motherboard.
