Disassembling Beats Pill 1.0
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling Beats Pill 1.0, Removing the Case Screws: step 1, image 1 of 3 Disassembling Beats Pill 1.0, Removing the Case Screws: step 1, image 2 of 3 Disassembling Beats Pill 1.0, Removing the Case Screws: step 1, image 3 of 3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Disassembling Beats Pill 1.0, Removing Center Cover: step 2, image 1 of 3 Disassembling Beats Pill 1.0, Removing Center Cover: step 2, image 2 of 3 Disassembling Beats Pill 1.0, Removing Center Cover: step 2, image 3 of 3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates.
  3. Disassembling Beats Pill 1.0, Separate the Device: step 3, image 1 of 3 Disassembling Beats Pill 1.0, Separate the Device: step 3, image 2 of 3 Disassembling Beats Pill 1.0, Separate the Device: step 3, image 3 of 3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: step 4, image 1 of 2 Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: step 4, image 2 of 2
    • Remove the speaker wire (yellow, red, black, white) from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: step 5, image 1 of 2 Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: step 5, image 2 of 2
    • Carefully remove the NFC sensor wire (black, red).
  6. Disassembling Beats Pill 1.0, Disconnect Control Wiring: step 6, image 1 of 2 Disassembling Beats Pill 1.0, Disconnect Control Wiring: step 6, image 2 of 2
    • Carefully remove the control cable(4 black, 1 red)
Dylan Cooper Dalrymple
741 Reputation
3 Guides authored
USF Tampa, Team 5-4, Blackwell Fall 2015 Member of USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 25
All Time: 4,405
