Dell XPS 13 9365 2-in-1 Battery Replacement
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: step 1, image 1 of 2 Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly with a Torx T4 screwdriver head.
    • Using your fingertips, open the system badge.
    • Remove the screw (M1.6x4) under the system badge that secures the base cover to the palm-rest assembly with a Phillips J000 screwdriver head.
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement, Remove Old Battery: step 2, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly with a Phillips J000 screwdriver head.
    • Remove the six screws (M2x3) that secure the battery to the palm-rest assembly with a Phillips 000 screwdriver head.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement, Lift Battery Out: step 3, image 1 of 1
    • Lift the battery off the palm-rest assembly.
    • If this is all you are doing, follow these steps in reverse to replace the battery. If not, go to the next guide.
Johnathan Hammond
44,980 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 101
All Time: 14,012
