Dell XPS 13 9365 2-in-1 Battery Replacement
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: step 1, image 1 of 2 Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
    • Using your fingertips, open the system badge.
    • Remove the screw (M1.6x4) under the system badge that secures the base cover to the palm-rest assembly.
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement, Remove Old Battery: step 2, image 1 of 1
    • Disconnect the battery cable from the system board.
    • Remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
    • Remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement, Lift Battery Out: step 3, image 1 of 1
    • Lift the battery off the palm-rest assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
44,980 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 101
All Time: 14,012
