Dell Vostro 500 Memory Module Replacement
  1. Dell Vostro 500 Memory Module Replacement, Removing the Battery: step 1, image 1 of 1
    • Slide the battery release latch toward the side of the computer until it is engaged.
    • Slide the battery out of the bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 500 Memory Module Replacement, Removing the Cover: step 2, image 1 of 1
    • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
  3. Dell Vostro 500 Memory Module Replacement, Popping up the Memory Module: step 3, image 1 of 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Johnathan Hammond
44,953 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,985 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 77
