Introduction
In this guide, will be showing you how to remove and replace the Memory Module.
Slide the battery release latch toward the side of the computer until it is engaged.
Slide the battery out of the bay.
Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
