Dell Latitude ST Battery Replacement
  1. Dell Latitude ST Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude ST Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude ST Battery Replacement, Battery: step 1, image 3 of 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Battery Replacement: step 2, image 1 of 3 Dell Latitude ST Battery Replacement: step 2, image 2 of 3 Dell Latitude ST Battery Replacement: step 2, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Battery Replacement: step 3, image 1 of 3 Dell Latitude ST Battery Replacement: step 3, image 2 of 3 Dell Latitude ST Battery Replacement: step 3, image 3 of 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Battery Replacement: step 4, image 1 of 3 Dell Latitude ST Battery Replacement: step 4, image 2 of 3 Dell Latitude ST Battery Replacement: step 4, image 3 of 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Battery Replacement: step 5, image 1 of 3 Dell Latitude ST Battery Replacement: step 5, image 2 of 3 Dell Latitude ST Battery Replacement: step 5, image 3 of 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Battery Replacement: step 6, image 1 of 3 Dell Latitude ST Battery Replacement: step 6, image 2 of 3 Dell Latitude ST Battery Replacement: step 6, image 3 of 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 937
