Introduction
In this guide you will find instructions on how to replace the USB motherboard of a Dell 1908FPc monitor.
Pop the front bezel off by inserting fingers underneath the left or right inside edge of screen.
A lot of pressure is required to remove the bezel. Do not be afraid of asserting some force.
Turn the monitor over. Unscrew the four 4mm x 10mm screws on the back of the monitor and remove the plastic backing.
Remove the five 3mm x 2mm screws that retain the metal cover protecting the electronics.
Remove the four 2.75mm x 6.75mm studs by the video imput ports.
Slide the cover downwards to unlock and remove cover.
Unplug board connections.
Uncsrew the four 3mm x 5.5mm screws that hold the USB motherboard down.
Get new board ready to install.
Follow steps in reverse order to reassemble the monitor.
If everything is done correctly, you should have a working monitor.
