Introduction
In this guide you will find instructions on how to replace the USB motherboard of a Dell 1908FPc monitor.
Pop the front bezel off by inserting fingers underneath the left or right inside edge of screen.
A lot of pressure is required to remove the bezel. Do not be afraid of asserting some force.
Turn the monitor over. Unscrew the four 4mm x 10mm screws on the back of the monitor and remove the plastic backing.
Remove the five 3mm x 2mm screws that retain the metal cover protecting the electronics.
Remove the four 2.75mm x 6.75mm studs by the video imput ports.
Slide the cover downwards to unlock and remove cover.
Unplug board connections.
Uncsrew the four 3mm x 5.5mm screws that hold the USB motherboard down.
Get new board ready to install.
