Dell 1908FPc Monitor USB Hard drive Replacement
  1. Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: step 1, image 1 of 3 Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: step 1, image 2 of 3 Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: step 1, image 3 of 3
    • Pop the front bezel off by inserting fingers underneath the left or right inside edge of screen.
    • Do not try to remove the bezel completely as there is a ribbon cable attached to the bottom for the buttons located in the bottom right hand corner.
    • A lot of pressure is required to remove the bezel. Do not be afraid of asserting some force.
    Ask FixBot
  2. Dell 1908FPc Monitor USB Hard drive Replacement: step 2, image 1 of 2 Dell 1908FPc Monitor USB Hard drive Replacement: step 2, image 2 of 2
    • Turn the monitor over. Unscrew the four 4mm x 10mm screws on the back of the monitor and remove the plastic backing.
    Ask FixBot
  3. Dell 1908FPc Monitor USB Hard drive Replacement: step 3, image 1 of 2 Dell 1908FPc Monitor USB Hard drive Replacement: step 3, image 2 of 2
    • Unscrew the 3mm x 4mm screw that retains the side USB shield.
    • Remove shield and set aside.
    Ask FixBot
  4. Dell 1908FPc Monitor USB Hard drive Replacement: step 4, image 1 of 3 Dell 1908FPc Monitor USB Hard drive Replacement: step 4, image 2 of 3 Dell 1908FPc Monitor USB Hard drive Replacement: step 4, image 3 of 3
    • Remove the five 3mm x 2mm screws that retain the metal cover protecting the electronics.
    • Remove the four 2.75mm x 6.75mm studs by the video imput ports.
    • Slide the cover downwards to unlock and remove cover.
    Ask FixBot
  5. Dell 1908FPc Monitor USB Hard drive Replacement: step 5, image 1 of 2 Dell 1908FPc Monitor USB Hard drive Replacement: step 5, image 2 of 2
    • Unplug board connections.
    • Uncsrew the four 3mm x 5.5mm screws that hold the USB motherboard down.
    • Get new board ready to install.
    Ask FixBot
You now know how to replace the USB motherboard on a Dell 1908FPc monitor.
Connor Henshaw
128 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 37
All Time: 841
