Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
Unscrew the two Phillips screws
The Phillips screw under the water tank can remain.
The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Some devices have a warming plate. Disconnect the flat plugs on the green/yellow protective earth conductors.
First loosen the detent on the edge. Use a thin flat-blade screwdriver to drive under the latch from behind. Insert a strong plastic lever tool into the gap between the control panel and the front. The latch opens with a loud crack.
Now you can open the other latches with the lever tool
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
