DeLonghi ESAM 3000.B Magnifica disassembling
Views: 31K
View statistics:
Past 24 Hours:
19
Past 7 Days:
166
Past 30 Days:
617
All Time:
31,324
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Most repairs require the Magnifica to be opened. This is shown here.
    1. DeLonghi ESAM 3000.B Magnifica disassembling, Preparations: step 1, image 1 of 1
      • Pull the plug!
      • Remove the drip tray, the water tank and the pulp container.
      Ask FixBot
    2. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: step 2, image 1 of 2 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: step 2, image 2 of 2
      • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
      Ask FixBot
    3. DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: step 3, image 1 of 2 DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: step 3, image 2 of 2
      • Slide the right side panel about 2 cm to the back.
      • Then solve it.
      Ask FixBot
    4. DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: step 4, image 1 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: step 4, image 2 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: step 4, image 3 of 3
      • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
      • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
      • Lift out the left side piece.
      Ask FixBot
    5. DeLonghi ESAM 3000.B Magnifica disassembling, Remove rear panel: step 5, image 1 of 1
      • Take out the rear panel.
      Ask FixBot
    6. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: step 6, image 1 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: step 6, image 2 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: step 6, image 3 of 3
      • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
      • Use a plastic opening tool to lever off the steam tap.
      • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
      • Do not pull the front panel too far, it is still attached with different hoses and cables.
      Ask FixBot
    7. DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: step 7, image 1 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: step 7, image 2 of 3 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: step 7, image 3 of 3
      • Two Phillips screws PH2 hold the lid at the back. Turn it out.
      • Lift the lid upwards.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
16 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
344,619 Reputation
317 Guides authored
4 Guide Comments
Bonjour et merci pour le partage;
Comment démonter le panneau de commandes à l’avant svp, il semblerait que le bouton rond qui permet de régler la quantité d’eau par tasse ne répond plus normalement. En effet en choisissant une double tasse et en ayant tourner ce bouton au maximum pour la quantité de café par tasse, j’obtiens un tiers de bol…ce bouton se serait il décalé??? ou est ce plutôt un autre problème? avez vous une idée svp? Merci d’avance pour vos réponses.
Laurence MUNSCH - Reply Share
Le régulateur réagit-il ? Si vous le retournez, est-ce qu'il produit aussi moins de café ? Il existe de nombreuses possibilités : le débitmètre, la pompe, le piston supérieur…
VauWeh - Reply Share
Bonjour j ai le bouton service toujours allumé. Pas détartrage mais je pense un problème électrique.
Qq peux m aider merci
yacoub bouanene - Reply Share
Utilisez le mode test pour trouver une solution. C'est en allemand, traduisez avec Google Translate.
Past 24 Hours: 19
Past 7 Days: 166
Past 30 Days: 617
All Time: 31,324
