DeLonghi ESAM xxxx - (Different Types) Replace timing belt
  1. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Preparations: step 1, image 1 of 1
    • Pull the plug!
    • Remove the drip tray, the water tank and the pulp container.
  2. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Unscrew the rear panel: step 2, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Unscrew the rear panel: step 2, image 2 of 2
    • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
  3. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove right side panel: step 3, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove right side panel: step 3, image 2 of 2
    • Slide the right side panel about 2 cm to the back.
    • Then solve it.
  4. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove left side panel: step 4, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove left side panel: step 4, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove left side panel: step 4, image 3 of 3
    • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
    • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
    • Lift out the left side piece.
  5. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove rear panel: step 5, image 1 of 1
    • Take out the rear panel.
  6. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Unscrew top cover: step 6, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Unscrew top cover: step 6, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Unscrew top cover: step 6, image 3 of 3
    • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
    • Use a plastic opening tool to lever off the steam tap.
    • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
    • Do not pull the front panel too far, it is still attached with different hoses and cables.
  7. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove top cover: step 7, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove top cover: step 7, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, Remove top cover: step 7, image 3 of 3
    • Two Phillips screws PH2 hold the lid at the back. Turn it out.
    • Lift the lid upwards.
  8. DeLonghi ESAM xxxx - (Different Types) Replace timing belt, timing belt: step 8, image 1 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, timing belt: step 8, image 2 of 3 DeLonghi ESAM xxxx - (Different Types) Replace timing belt, timing belt: step 8, image 3 of 3
    • This is what the timing belt looks like.
    • Lay the machine on its side.
    • The bottom panel is secured with five Torx TR15 security screws. turn them out.
    • Take off the bottom plate. The toothed belt becomes visible.
  9. DeLonghi ESAM xxxx - (Different Types) Replace timing belt: step 9, image 1 of 2 DeLonghi ESAM xxxx - (Different Types) Replace timing belt: step 9, image 2 of 2
    • It's easier if you loosen the motor.
    • Remove the four Phillips screws securing the motor. (Two are obscured in the picture). Loosen the motor and push it up a little.
    • Lift off the timing belt.
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,869 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,110 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 373
