ECAM 2XXX test mode
  1. ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 1 of 3 ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 2 of 3 ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 3 of 3
    • Unplug the power cord. The switch on the back must be turned on. There must be water in the tank and all trays must be inserted.
    • Press and hold the "one cup" and "water" buttons at the same time.
    • Plug the connector back in and release the buttons.
    • The indication of the test mode appears on the display.
    Ask FixBot
  2. ECAM 2XXX test mode: step 2, image 1 of 1
    • You now can test various important components; the corresponding message appears on the display:
    • Pressing the rotary switch in the middle activates the solenoid valve 2 for the steam. (Ev2, at the top of the machine) You should hear it click.
    Ask FixBot
  3. ECAM 2XXX test mode: step 3, image 1 of 1
    • The functions for the square buttons are:
    • Both solenoid valves switch.
    • Solenoid valve 1 for the coffee (Ev1, at the bottom of the machine) switches.
    • The heater for the coffee gets warm.
    • Motor moves to the end positions and then reverses as long as the button is pressed.
    • The grinder is running.
    • The pump is running.
    • The cappuccino button at the bottom left switches the steam heater.
    Ask FixBot
Reverse the steps to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
334,672 Reputation
311 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
36 Members
1,676 Guides authored
2 Guide Comments
Handleiding gaat niet over machine met knoppen. Ik heb eentje met knoppen zonder display. Wat nu?
Sietske - Reply Share
ich habe eine ECAM22.366 Magnifica S Cappucino. da funktioniert es so nicht. Im Display steht weiterhin "Brühgruppe einsetzen"
Christian - Reply Share
Past 24 Hours: 11
Past 7 Days: 74
Past 30 Days: 339
All Time: 7,537
