Shop the Holiday Gift Guide
Damaged Wire Replacement
Views: 82K
View statistics:
Past 24 Hours:
31
Past 7 Days:
280
Past 30 Days:
1,073
All Time:
82,071
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 48
48 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If a damaged wire is causing electrical supply issues to a device, component or applience, use this guide to replace the damaged section of the wire.
Many electronic devices use wires as a means of transferring electrical power to an appliance enableing it to work. However, wires can be worn down over time. A severed wire will cut off electrial supply to the wire itself. Exposed wires can cause injury due to electrical shock, fire or electricution.
Before using this guide, confirm that the damaged wire is the problem. Begin by determining if the device/applience is recieving any power at all. After unplugging/disconnecting the wire, throughly inspect it for any inconsistancies or suspected problem areas that could be causing issues.
Step 3 involves the task of stripping wires while steps 4-7 also require the use of heat shrink tubing. Be sure to familiarise yourself with these techniques beforehand.
Note: In these guide the cable is not soldered. An additional soldered connection can increase safety.
Before starting, it is important to make sure that the wire you will be conducting the repair on is unpluged/unconnected so that no electrical current will be running through it.
    1. Damaged Wire Replacement, Trim Away Damaged Portion: step 1, image 1 of 3 Damaged Wire Replacement, Trim Away Damaged Portion: step 1, image 2 of 3 Damaged Wire Replacement, Trim Away Damaged Portion: step 1, image 3 of 3
      • Using pliers, trim away the damaged portion of the wire.
      • You should be left with two neatly trimmed wire ends.
      Ask FixBot
    2. Damaged Wire Replacement, Cut Replacement Wire: step 2, image 1 of 2 Damaged Wire Replacement, Cut Replacement Wire: step 2, image 2 of 2
      • Cut a new replacement section of wire. This section will be connected between the two wires in the previous step.
      • The length of this new section varies for each repair. You decide what length is most suitable for your fix.
      Ask FixBot
    3. Damaged Wire Replacement, Strip Wire Ends: step 3, image 1 of 3 Damaged Wire Replacement, Strip Wire Ends: step 3, image 2 of 3 Damaged Wire Replacement, Strip Wire Ends: step 3, image 3 of 3
      • Using the wire strippers, strip roughly the first 1-2cm of wire insulation on each end.
      • The result should look as illustrated in the third picture.
      Ask FixBot
    4. Damaged Wire Replacement, Slide Heat Shrink On To Wire: step 4, image 1 of 2 Damaged Wire Replacement, Slide Heat Shrink On To Wire: step 4, image 2 of 2
      • Slide a piece heat shrink tubing onto both ends of the main wires.
      Ask FixBot
    5. Damaged Wire Replacement, Fray Wire Ends: step 5, image 1 of 2 Damaged Wire Replacement, Fray Wire Ends: step 5, image 2 of 2
      • Using pliers, slightly fray the ends of each of the exposed wires.
      • Small exposed wires are extremely sharp and can cause injury to bare hands.
      Ask FixBot
    6. Damaged Wire Replacement, Crimp Wire Ends Together: step 6, image 1 of 2 Damaged Wire Replacement, Crimp Wire Ends Together: step 6, image 2 of 2
      • Using the pliers, connect each of the wire segments by intertwining and twisting them together.
      • Once done, lightly crimp each of the connections with the pliers.
      Ask FixBot
    7. Damaged Wire Replacement, Use Heatgun: step 7, image 1 of 2 Damaged Wire Replacement, Use Heatgun: step 7, image 2 of 2
      • Slide the heat shrink tubing over the exposed wires.
      • Using the heat gun, slowly go back and forth over the shrink wrap, allowing for even heat distribution and the wrap to close.
      • Depending on the heat gun setting, shrink wraps should take anywhere from 10-25 seconds to fully constrict around the wire.
      • Heat guns take little time to heat up and much longer to cool down. Use caution when setting this tool down and make sure it's cool when picking it up after use.
      Ask FixBot
    8. Damaged Wire Replacement, Repair Is Complete!: step 8, image 1 of 1
      • Throughly check for any exposed wires and the heat shrink tubing is tight around the wire.
      Ask FixBot
After inspecting the replaced section, the repair is complete and the wire is ready to be tested.
48 other people completed this guide.
Author
with
Nicholas Pierson
1,622 Reputation
1 Guide authored
6 Guide Comments
Muito ruim!!
Ivanilson - Reply Share
Heat shrink is for strain relief - not joining cables. I'd suggest solder sleeves. You'd need a heat gun either way, but this method solders the connection and provides an environmental shield on both ends.
Josh Bowen - Reply Share
The wires really should be soldered together before putting the heat shrink over the connection. A connection made with this guide could rather easily be broken with a slight pull on the cable. In the worst case, it could cause an electric shock to the user.
HoPo-_ - Reply Share
Bonjour,
Vous pouvez aussi souder les deux câbles ensemble avant de mettre la gaine thermo en utilisant des connecteurs auto-soudeur que vous pouvez retrouver en cliquant ici.
Merci
Kevin - Reply Share
何必多間中間那一段 只需要將毀損的部位修平 再將兩頭末端連接即可 多那段有點多餘
Chiu_Chieh - Reply Share
Past 24 Hours: 31
Past 7 Days: 280
Past 30 Days: 1,073
All Time: 82,071
