Shop the Holiday Gift Guide
How to create a bootable USB drive
Views: 972K
View statistics:
Past 24 Hours:
106
Past 7 Days:
721
Past 30 Days:
3,033
All Time:
971,550
Comments: 210
109 comments on steps, 101 guide comments.
Go to guide comments
Completed: 228
228 people have marked this guide "completed." Will you be next?
Favorites: 55
55 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 2 hours
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Create a bootable USB drive for macOS X El Capitan, Yosemite, Mavericks, Sierra, High Sierra, Mojave, Catalina, Big Sur, Monterey, Ventura Sonoma.
(The process is also described on the Apple Support page https://support.apple.com/en-us/HT201372)
    1. How to create a bootable USB drive, How to create a bootable USB drive: step 1, image 1 of 3 How to create a bootable USB drive, How to create a bootable USB drive: step 1, image 2 of 3 How to create a bootable USB drive, How to create a bootable USB drive: step 1, image 3 of 3
      • If you're currently running macOS Mojave, click this link to find the Mojave installer in the App Store. For Catalina, click here.
      • For all earlier versions of macOS, launch the App Store on your Mac, and search for the macOS version you want (this option is only available when running macOS High Sierra and lower)
      • Click Get or Download
      • If you have previously downloaded this version of macOS using the current Apple ID account, you might find it in the "Purchased"tab.
      • The installer is not directly available to Windows users. If you're using Windows, in order to get access to the installer, you'll need to borrow a macOS machine, go to a Apple Retail Store and download it there, or use a Hackintosh.
      Ask FixBot
    2. How to create a bootable USB drive: step 2, image 1 of 2 How to create a bootable USB drive: step 2, image 2 of 2
      • After the downloading process is complete, close the App Store. The installation window should appear afterwards.
      • [*red]Click the "Install macOS (whatever version you have downloaded)" menu at the top left of the screen, and select "Quit Install macOS (whatever version you have) ."
      Ask FixBot
    3. How to create a bootable USB drive: step 3, image 1 of 1
      • Insert your USB drive into your Mac's USB port.
      • Open Finder to find your USB or if your Finder preferences have been set, you can find it on the Desktop.
      • Your USB drive will be completely erased in the following steps. Make any backups of your data beforehand.
      Ask FixBot
    4. How to create a bootable USB drive: step 4, image 1 of 3 How to create a bootable USB drive: step 4, image 2 of 3 How to create a bootable USB drive: step 4, image 3 of 3
      • Launch Terminal.
      • You can either use Spotlight or navigate to "Utilities" inside of Applications within Finder and double click Terminal.
      Ask FixBot
    5. How to create a bootable USB drive: step 5, image 1 of 2 How to create a bootable USB drive: step 5, image 2 of 2
      • In Terminal, type one of the following commands, depending on your version of macOS. (The name of the version of macOS, is the one you want to install on the key and downloaded.)
      • Instead of "/Volumes/MyVolume", type the name of your USB drive. Type everything else exactly as you see it (or better yet, copy and paste it from here).
      • For El Capitan : sudo /Applications/Install\ OS\ X\ El\ Capitan.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ El\ Capitan.app
      • For Yosemite : sudo /Applications/Install\ OS\ X\ Yosemite.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ Yosemite.app
      • For Mavericks : sudo /Applications/Install\ OS\ X\ Mavericks.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ OS\ X\ Mavericks.app
      • For Sierra : sudo /Applications/Install\ macOS\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ macOS\ Sierra.app
      • Other versions, see the next step.
      Ask FixBot
      • For High Sierra : sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ macOS\ High\ Sierra.app
      • For Mojave : sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Catalina: sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Big Sur: sudo /Applications/Install\ macOS\ Big\ Sur.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Monterey : sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Ventura : sudo /Applications/Install\ macOS\ Ventura.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Sonoma : sudo /Applications/Install\ macOS\ Sonoma.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • For Sequoia : sudo /Applications/Install\ macOS\ Sequoia.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      Ask FixBot
      • For Tahoe : sudo /Applications/Install\ macOS\ Tahoe.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
      • If you see the error "Does not appear to be a valid OS installer application", delete and then re-download your macOC image.
      Ask FixBot
    6. How to create a bootable USB drive: step 8, image 1 of 2 How to create a bootable USB drive: step 8, image 2 of 2
      • After correctly entering the command with the name of your USB drive, press the [return] key.
      • Enter the macOS administrator password.
      • Your password will not be displayed.
      • Press [return].
      • Check the name and path of your USB key. If it looks correct, press the [Y] key, then press [return].
      • The bootable drive creation will begin. Please wait until the process completes.
      Ask FixBot
    7. How to create a bootable USB drive: step 9, image 1 of 1
      • When Terminal indicates the process is "Done," the creation of your bootable drive has succeeded.
      • To boot off the USB, first make sure the Mac is off and then press and hold the [option] key when you hear the chime/turn it on .
      Ask FixBot
Nice work! You're done.
228 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Anthony Fassler
7,134 Reputation
4 Guides authored
101 Guide Comments
if it is possible with power iso i have installed this one on my system. http://standaloneinstaller.com/download-...
kennieboezi - Reply Share
You mean create a USB key from Windows ?
Anthony Fassler - Reply Share
Absolutely possible because I successfully created a Big Sur USB installer on my Windows 10 PC with UUByte DMG Editor.
However, you should download the macOS dmg file first. This software can quickly burn DMG file to USB and you will get a bootable macOS USB disk in a few minutes.
BTW, it also has a Mac version you can try out.
Johin114 - Reply Share
I'm thinking of using this method to revert back to an older os due to my mac slowing down with Sierra. Will I be able to install just Yosemite or el capitan? Without installing previous os upgrades? This way I can have a fresh mac book.
skylerzanth - Reply Share
Hello,
Yes you can but with this method, we must make a clean install.
So, please sure you save all your data to another hard drive.
Past 24 Hours: 106
Past 7 Days: 721
Past 30 Days: 3,033
All Time: 971,550
