Introduction
Remove the back cover and replace the whole battery.
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Use a metal spudger to separate the back cover from the front touch screen.
To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
Continue to separate all of the clips around the device until the back cover comes off completely.
Locate the white plug next to the battery.
Use your fingers to pull off white plug that connected to the battery.
The battery should only be connected to the LCD by adhesive tape.
Using force, carefully remove the battery while holding the LCD in place.
