Canon PowerShot SX260 HS LCD Screen Replacement
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: step 2, image 1 of 1
    • Use your plastic opening tool to gently lift and remove back face plate.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: step 3, image 1 of 1
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: step 4, image 1 of 1
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: step 5, image 1 of 1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: step 6, image 1 of 1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: step 7, image 1 of 1
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: step 8, image 1 of 1
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: step 9, image 1 of 1
    • Gently slide the LCD screen to the right and remove.
Tyler Kelch
622 Reputation
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 3,772
