Introduction
If you need to replace your LCD Screen on your Canon PowerShot SX260 HS this guide is for you!
The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
Remove the 2 (3 mm) screws on the left side
Remove the 2 (3 mm) screws on the bottom of the camera.
Remove the 2 (3 mm) screws on the right side of the camera.
After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
Gently lift the panel with your fingers.
