Introduction
Beats mixr have a very flexible headband that is made to bend in different ways. After time, the headband can weaken and break. Luckily, it is an easy fix.
Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
