Beats Mixr Headband Replacement
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: step 1, image 1 of 1
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: step 2, image 1 of 1
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
Allie Horton
929 Reputation
1 Guide authored
USF Tampa, Team 1-11, Donnelly Fall 2014 Member of USF Tampa, Team 1-11, Donnelly Fall 2014
USFT-DONNELLY-F14S1G11
1 Member
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 14,435
