Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the OnePlus Nord 2 5G.
Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
Insert an iFlex into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap. This may require some force.
Leave the iFlex in place to prevent the adhesive from resealing.
Insert an opening pick into the gap you created with the iFlex.
Remove the iFlex.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top left corner of the rear glass.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top right corner.
Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to remove the metal bracket covering the flash assembly connector.
Use the point of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
Insert an opening pick underneath the bottom right edge of the motherboard cover.
Twist the opening pick sideways release the plastic clips and to pry up the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus Nord 2 5G answers community for help.
