Shop the Holiday Gift Guide
Battery Disconnection
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
25
All Time:
221
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the Xiaomi Redmi Note 11 Pro.
Parts
Tools
    1. Battery Disconnection, Heat the rear glass: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Battery Disconnection, Insert an opening pick: step 2, image 1 of 3 Battery Disconnection, Insert an opening pick: step 2, image 2 of 3 Battery Disconnection, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
      • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Battery Disconnection, Slice the bottom edge adhesive: step 3, image 1 of 2 Battery Disconnection, Slice the bottom edge adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Battery Disconnection, Slice the left edge adhesive: step 4, image 1 of 3 Battery Disconnection, Slice the left edge adhesive: step 4, image 2 of 3 Battery Disconnection, Slice the left edge adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Battery Disconnection: step 5, image 1 of 2 Battery Disconnection: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Battery Disconnection: step 6, image 1 of 2 Battery Disconnection: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
      • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
      Ask FixBot
    7. Battery Disconnection, Remove the rear glass: step 7, image 1 of 2 Battery Disconnection, Remove the rear glass: step 7, image 2 of 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. Battery Disconnection, Eject the SIM card tray: step 8, image 1 of 3 Battery Disconnection, Eject the SIM card tray: step 8, image 2 of 3 Battery Disconnection, Eject the SIM card tray: step 8, image 3 of 3
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the bottom edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
      Ask FixBot
    2. Battery Disconnection, Unfasten the midframe screws: step 9, image 1 of 2 Battery Disconnection, Unfasten the midframe screws: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the seventeen 3.6 mm-long screws securing the midframe.
      Ask FixBot
    3. Battery Disconnection, Insert an opening pick: step 10, image 1 of 2 Battery Disconnection, Insert an opening pick: step 10, image 2 of 2
      • The midframe of the Xiaomi Redmi Note 11 Pro is held in place by plastic clips.
      • Insert an opening pick between the midframe and front panel assembly on the bottom left edge of the phone where the SIM tray slot is located.
      Ask FixBot
    4. Battery Disconnection, Release the plastic clips: step 11, image 1 of 2 Battery Disconnection, Release the plastic clips: step 11, image 2 of 2
      • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
      • Slide the opening pick around the bottom left corner of the phone to release the plastic clips.
      Ask FixBot
    5. Battery Disconnection: step 12, image 1 of 3 Battery Disconnection: step 12, image 2 of 3 Battery Disconnection: step 12, image 3 of 3
      • Slide the opening pick along the left edge of the phone to release the plastic clips.
      Ask FixBot
    6. Battery Disconnection: step 13, image 1 of 3 Battery Disconnection: step 13, image 2 of 3 Battery Disconnection: step 13, image 3 of 3
      • Slide the opening pick around the top left corner and along the top edge of the phone to release the plastic clips.
      Ask FixBot
    7. Battery Disconnection: step 14, image 1 of 3 Battery Disconnection: step 14, image 2 of 3 Battery Disconnection: step 14, image 3 of 3
      • Slide the opening pick around the top right corner and along the right edge of the phone to release the remaining plastic clips.
      • Do not try to remove the midframe all the way yet. The midframe cable is still connected to the motherboard.
      Ask FixBot
    8. Battery Disconnection, Free the midframe cable connector: step 15, image 1 of 3 Battery Disconnection, Free the midframe cable connector: step 15, image 2 of 3 Battery Disconnection, Free the midframe cable connector: step 15, image 3 of 3
      • Carefully swing open the midframe to the left like you would open the front cover of a book to get free access to its cable connector.
      • Place the midframe next to the left edge of the front panel assembly.
      Ask FixBot
    9. Battery Disconnection, Disconnect the midframe cable: step 16, image 1 of 2 Battery Disconnection, Disconnect the midframe cable: step 16, image 2 of 2
      • Use a spudger to disconnect the midframe cable by prying the connector straight up from its socket.
      Ask FixBot
    10. Battery Disconnection, Remove the midframe: step 17, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Battery Disconnection, Disconnect the battery cables: step 18, image 1 of 3 Battery Disconnection, Disconnect the battery cables: step 18, image 2 of 3 Battery Disconnection, Disconnect the battery cables: step 18, image 3 of 3
      • Use a spudger to disconnect the left and right battery cable by prying the connectors straight up from their socket.
      Ask FixBot
Dominik Schnabelrauch
267,900 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 25
All Time: 221
