Up to 20% off select tools
Battery Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
37
All Time:
325
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 seconds
Difficulty: Very easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Battery Disconnect
Tools
Introduction
Go to step 1 ↓
prereq battery disconnect
    1. Battery Disconnect, Back Cover: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Battery Disconnect: step 2, image 1 of 3 Battery Disconnect: step 2, image 2 of 3 Battery Disconnect: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom left corner.
      Ask FixBot
    3. Battery Disconnect: step 3, image 1 of 2 Battery Disconnect: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Battery Disconnect: step 4, image 1 of 3 Battery Disconnect: step 4, image 2 of 3 Battery Disconnect: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Battery Disconnect: step 5, image 1 of 2 Battery Disconnect: step 5, image 2 of 2
      • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Battery Disconnect: step 6, image 1 of 2 Battery Disconnect: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Battery Disconnect: step 7, image 1 of 2 Battery Disconnect: step 7, image 2 of 2
      • Lift and remove the back cover.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      Ask FixBot
    1. Battery Disconnect, Battery Disconnect: step 8, image 1 of 3 Battery Disconnect, Battery Disconnect: step 8, image 2 of 3 Battery Disconnect, Battery Disconnect: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully peel the adhesive strip off the mother board and the battery and remove it.
      Ask FixBot
    2. Battery Disconnect: step 9, image 1 of 2 Battery Disconnect: step 9, image 2 of 2
      • Use a pair of tweezers to peel the black adhesive strip off the battery connector and fold it out of the way.
      Ask FixBot
    3. Battery Disconnect: step 10, image 1 of 2 Battery Disconnect: step 10, image 2 of 2
      • Use a spudger to pry up and disconnect the battery connector.
      Ask FixBot
Author
with
Dominik Schnabelrauch
268,103 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 325
