Introduction
This guide will show the steps to take out and replace a defective Ram for the Asus UL30VT-X1.
Locate the two screws on the ram panel.
Unscrew the two screws using a Phillips Head #00 screwdriver.
Locate the small cut out at the bottom of the ram panel.
Lift the rem panel up with your finger and remove it to expose the ram.
locate the white clips on the sides of the ram.
Push the white clips to the side so the ram pops out
Afterword use your fingers to pull the ram towards you.
