Asus UL30VT-X1 Ram Replacement
  1. Asus UL30VT-X1 Ram Replacement, Ram: step 1, image 1 of 2 Asus UL30VT-X1 Ram Replacement, Ram: step 1, image 2 of 2
    • Flip the laptop over onto the back.
  2. Asus UL30VT-X1 Ram Replacement: step 2, image 1 of 1
    • Locate the two screws on the ram panel.
    • Unscrew the two screws using a Phillips Head #00 screwdriver.
  3. Asus UL30VT-X1 Ram Replacement: step 3, image 1 of 1
    • Locate the small cut out at the bottom of the ram panel.
    • Lift the rem panel up with your finger and remove it to expose the ram.
  4. Asus UL30VT-X1 Ram Replacement: step 4, image 1 of 2 Asus UL30VT-X1 Ram Replacement: step 4, image 2 of 2
    • locate the white clips on the sides of the ram.
    • Push the white clips to the side so the ram pops out
    • Afterword use your fingers to pull the ram towards you.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 190
