Introduction
This repair will need:
A T8 Torx Screwdriver.
With the Generally Disassembly completed, you may proceed to floppy drive installation.
Reverse the computer to access the peripheral panel in the back.
Remove the two T8 Torx screws on either side of the bar code panel.
Reverse the computer to have the monitor and mousepad facing you.
Remove the plastic panel underneath the display.
Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Replace the defective drive with a new drive.
Follow these instructions in reverse order to reassemble the device.
