American Weigh AWS -100 Sensor Replacement
  1. American Weigh AWS -100 Sensor Replacement, Sensor: step 1, image 1 of 1
    • Flip the device over and remove the battery cover.
  2. American Weigh AWS -100 Sensor Replacement: step 2, image 1 of 1
    • Remove the two screws (length: 7/16") located underneath the battery cover. Use a Phillip's head number 1 screwdriver.
  3. American Weigh AWS -100 Sensor Replacement: step 3, image 1 of 1
    • Once the screws are removed, lift up the metal weighing plate with your hands. At this point in the process, the sensor will still be attached.
  4. American Weigh AWS -100 Sensor Replacement: step 4, image 1 of 1
    • Using your hands or a plastic opening tool, peel back the metal plate from the plastic underneath. This will expose the screws connecting the sensor to the plastic.
  5. American Weigh AWS -100 Sensor Replacement: step 5, image 1 of 1
    • Using the same screwdriver as before, remove the two screws (length 3/8") on the plastic plate connected the sensor.
  6. American Weigh AWS -100 Sensor Replacement: step 6, image 1 of 2 American Weigh AWS -100 Sensor Replacement: step 6, image 2 of 2
    • With the sensor detached, use a plastic opening tool to peel away the glue holding the wires.
  7. American Weigh AWS -100 Sensor Replacement: step 7, image 1 of 2 American Weigh AWS -100 Sensor Replacement: step 7, image 2 of 2
    • Remove the glue on the third side so that the wires are completely disconnected from the sensor. You should now be able to replace the defective sensor with your new one.
Robert Muehler
297 Reputation
2 Guides authored
USF Tampa, Team 1-2, Sullivan Fall 2015 Member of USF Tampa, Team 1-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G2
3 Members
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 40
All Time: 5,668
