Introduction
This guide will show users how to replace the LCD screen on the Amazon Kindle DX in just a few simple steps.
Please note: This guide shows the use of incorrect tools. Always use the appropriate tools when handling delicate internal components of the device to avoid any complications with electrostatic discharge.
Take your Kindle and place it screen side down in order to open it from the back. Use the opening tool from the ifixit tool kit and insert it between the metal casing and plastic top piece.
Once the small plastic piece is removed you will need to locate two 40mm screws on both corners of the remaining casing. Use the PH000 Philips Head Screwdriver from the tool kit to remove both screws.
Locate the two 30mm screws securing the battery on the bottom of the Kindle DX. Use the PH00 Philips head screw driver from the tool kit to remove both screws.
