Amazon Kindle DX LCD Replacement
  1. Amazon Kindle DX LCD Replacement, Liquid Crystal Display (LCD): step 1, image 1 of 1
    • Take your Kindle and place it screen side down in order to open it from the back. Use the opening tool from the ifixit tool kit and insert it between the metal casing and plastic top piece.
  2. Amazon Kindle DX LCD Replacement: step 2, image 1 of 1
    • Once enough pressure is applied the small piece will pop open.
  3. Amazon Kindle DX LCD Replacement: step 3, image 1 of 1
    • Remove the plastic piece.
  4. Amazon Kindle DX LCD Replacement: step 4, image 1 of 2 Amazon Kindle DX LCD Replacement: step 4, image 2 of 2
    • Once the small plastic piece is removed you will need to locate two 40mm screws on both corners of the remaining casing. Use the PH000 Philips Head Screwdriver from the tool kit to remove both screws.
  5. Amazon Kindle DX LCD Replacement: step 5, image 1 of 1
    • Use the opening tool again to take the off the bigger metal piece.
  6. Amazon Kindle DX LCD Replacement: step 6, image 1 of 1
    • Once the piece removed, locate the battery.
  7. Amazon Kindle DX LCD Replacement: step 7, image 1 of 2 Amazon Kindle DX LCD Replacement: step 7, image 2 of 2
    • Locate the two 30mm screws securing the battery on the bottom of the Kindle DX. Use the PH00 Philips head screw driver from the tool kit to remove both screws.
  8. Amazon Kindle DX LCD Replacement: step 8, image 1 of 2 Amazon Kindle DX LCD Replacement: step 8, image 2 of 2
    • Take the battery off once the screws have been removed.
  9. Amazon Kindle DX LCD Replacement: step 9, image 1 of 2 Amazon Kindle DX LCD Replacement: step 9, image 2 of 2
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as shown in the picture.
  10. Amazon Kindle DX LCD Replacement: step 10, image 1 of 2 Amazon Kindle DX LCD Replacement: step 10, image 2 of 2
    • Unscrew the 30 mm screws using a Phillips #000 screwdriver as demonstrated in the picture.
  11. Amazon Kindle DX LCD Replacement: step 11, image 1 of 1
    • Remove the black case to reveal the mother board.
  12. Amazon Kindle DX LCD Replacement: step 12, image 1 of 1
    • Remove the motherboard from the display assembly.
Lori White
557 Reputation
3 Guides authored
USF Tampa, Team 1-5, Cagle Fall 2016 Member of USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 3,311
