Introduction
If your Alcatel 1B 2020 is taking blurry photos, it may be due to a bad rear camera. Symptoms like distorted images, inability to focus, or a non-functional camera may indicate a problem with the camera. A replacement may be necessary if general troubleshooting has not resolved the issue.
This guide will focus on showing you how to replace the rear camera on your Alcatel 1B 2020. The repair is straightforward, only requiring a few screws to be taken out and some prying.
If your Alcatel 1B 2020 has a swollen battery after opening the phone, handle it carefully, as it poses a fire hazard.
Following these steps in this guide will help you successfully replace your Alcatel 1B 2020's rear camera.
Insert the opening tool into the seam between the back plastic case and the front screen.
Slide it around the edge of the phone to release the clips holding them together.
Remove the bottom case by hand.
Use a Phillips #000 screwdriver to remove sixteen 3.0 mm screws that secure the black plastic bracket.
Place a spudger or an opening tool under the camera press connector edge and pry straight up to disconnect it.
Use the tweezers to pull the rear camera out.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
