Introduction
Use this guide to replace the battery in your ASUS TUF Gaming F15 FX506HEB-DB74 Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Remove the 11 Phillips screws securing the lower case:
Seven 11.6 mm screws
Two 14.6 mm screws
Two 6.1 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the right edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Use your fingers to move the plastic that covers the battery connector out of the way.
Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
Use a Phillips screwdriver to remove the two 6.1 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
