ASUS ROG Raikiri Pro Battery Replacement
    1. ASUS ROG Raikiri Pro Battery Replacement, Battery: step 1, image 1 of 3 ASUS ROG Raikiri Pro Battery Replacement, Battery: step 1, image 2 of 3 ASUS ROG Raikiri Pro Battery Replacement, Battery: step 1, image 3 of 3
      • Make sure your controller is completely turned off before proceeding.
      • Insert the tip of an opening pick into the seam of the top left handle cover.
      • Slide it down to release the clips connecting the handle cover to the controller.
      • Remove the left handle-cover.
      • Repeat the steps to remove the right handle cover.
      Ask FixBot
    2. ASUS ROG Raikiri Pro Battery Replacement: step 2, image 1 of 3 ASUS ROG Raikiri Pro Battery Replacement: step 2, image 2 of 3 ASUS ROG Raikiri Pro Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
      Ask FixBot
    3. ASUS ROG Raikiri Pro Battery Replacement: step 3, image 1 of 2 ASUS ROG Raikiri Pro Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
      Ask FixBot
    4. ASUS ROG Raikiri Pro Battery Replacement: step 4, image 1 of 2 ASUS ROG Raikiri Pro Battery Replacement: step 4, image 2 of 2
      • Place the tip of an opening pick or spudger in the seam of the back center panel.
      • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
      • Separate the top and bottom of the device.
      Ask FixBot
    5. ASUS ROG Raikiri Pro Battery Replacement: step 5, image 1 of 2 ASUS ROG Raikiri Pro Battery Replacement: step 5, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
      • Disconnect the ribbon cable that crosses over the battery.
      Ask FixBot
    6. ASUS ROG Raikiri Pro Battery Replacement: step 6, image 1 of 2 ASUS ROG Raikiri Pro Battery Replacement: step 6, image 2 of 2
      • Use a spudger to carefully remove the board and left rumble motor.
      Ask FixBot
    7. ASUS ROG Raikiri Pro Battery Replacement: step 7, image 1 of 2 ASUS ROG Raikiri Pro Battery Replacement: step 7, image 2 of 2
      Ask FixBot
    8. ASUS ROG Raikiri Pro Battery Replacement: step 8, image 1 of 1
      • Gently remove the battery from its enclosure.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 92
All Time: 943
