Introduction
To remove the cover of the tablet you will need a plastic prying tool and 1mm Phillips Screwdriver. Be sure to allot roughly 2-3 minutes for the process. If you don't have a plastic prying tool, your fingers should suffice.
Take tablet and rotate on its side, so that the two screws are facing upward.
Use Phillips #00 Screwdriver to remove two 1mm screws on the left side of the tablet.
Insert plastic prying tool and pry back case away from the device slowly moving the plastic prying tool along the device.
Hold positive and negative wires as close as possible to the speaker.
Use plastic prying tool and fingers to simultaneously lift speaker from cover.
