4Sight 9 Cover Replacement
  1. 4Sight 9 Cover Replacement, Cover: step 1, image 1 of 2 4Sight 9 Cover Replacement, Cover: step 1, image 2 of 2
    • Take tablet and rotate on its side, so that the two screws are facing upward.
    • Use Phillips #00 Screwdriver to remove two 1mm screws on the left side of the tablet.
  2. 4Sight 9 Cover Replacement: step 2, image 1 of 1
    • Insert plastic prying tool and pry back case away from the device slowly moving the plastic prying tool along the device.
    • Once loosened, use hands to help separate case from device.
  3. 4Sight 9 Cover Replacement: step 3, image 1 of 2 4Sight 9 Cover Replacement: step 3, image 2 of 2
    • Hold positive and negative wires as close as possible to the speaker.
    • Use plastic prying tool and fingers to simultaneously lift speaker from cover.
    • Set cover aside.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 717
