2008-2013 Subaru Forester Cabin Air Filter Replacement
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: step 1, image 1 of 1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 2, image 1 of 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 2, image 2 of 2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 3, image 1 of 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 3, image 2 of 2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 4, image 1 of 2 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 4, image 2 of 2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 5, image 1 of 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 5, image 2 of 3 2008-2013 Subaru Forester Cabin Air Filter Replacement: step 5, image 3 of 3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 63
All Time: 6,665
