Samsung Galaxy S25 Ultra USB-C Board Replacement
  1. Samsung Galaxy S25 Ultra USB-C Board Replacement, Safety precautions: step 1, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Safety precautions: step 1, image 2 of 2
    • Let your Galaxy's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone by holding the side key and volume down button and selecting Power off.
    Ask FixBot
  2. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the SIM card tray: step 2, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the SIM card tray: step 2, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the SIM card tray: step 2, image 3 of 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of your phone until the tray ejects.
    • A small mic hole is next to the SIM tray—don't confuse the two!
    • Remove the SIM card tray.
    Ask FixBot
  3. Samsung Galaxy S25 Ultra USB-C Board Replacement, Cracked glass preparation: step 3, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Cracked glass preparation: step 3, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Cracked glass preparation: step 3, image 3 of 3
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
    • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
    • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Ask FixBot
  4. Samsung Galaxy S25 Ultra USB-C Board Replacement, Heat the back cover: step 4, image 1 of 1
    • Adhesive secures the back cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the back cover for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the cover.
    • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
    Ask FixBot
  5. Samsung Galaxy S25 Ultra USB-C Board Replacement, Adhesive information: step 5, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Adhesive information: step 5, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Adhesive information: step 5, image 3 of 3
    • While the back cover heats, note the following about its adhesive:
    • The cover is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
    • Only insert your tool slightly under the cover near the cameras to avoid damaging them.
    Ask FixBot
  6. Samsung Galaxy S25 Ultra USB-C Board Replacement, Apply a suction handle: step 6, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Apply a suction handle: step 6, image 2 of 2
    • Apply a suction handle to the center of the back cover's bottom edge, as close to the edge as possible.
    Ask FixBot
  7. Samsung Galaxy S25 Ultra USB-C Board Replacement, Insert an opening pick: step 7, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Insert an opening pick: step 7, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Insert an opening pick: step 7, image 3 of 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
    • Use the fingers of your lifting hand to hold the phone down, or steady the frame with your free hand—be careful, your phone may be hot.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  8. Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • If the back cover feels stuck at any point when separating the adhesive, apply heat to the area and try again.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    Ask FixBot
  9. Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the right edge adhesive: step 9, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the right edge adhesive: step 9, image 2 of 2
    • Slide the opening pick around the bottom right corner and up the right edge to separate the adhesive.
    Ask FixBot
  10. Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the top edge adhesive: step 10, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the top edge adhesive: step 10, image 2 of 2
    • In the next two steps, only insert the pick slightly (a few millimeters) near the cameras to avoid damaging them.
    • Slide the opening pick around the top right corner and along the top edge to separate the adhesive.
    Ask FixBot
  11. Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the left edge adhesive: step 11, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Separate the left edge adhesive: step 11, image 2 of 2
    • Slide the opening pick around the top left corner and down the left edge to separate the adhesive.
    Ask FixBot
  12. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the back cover: step 12, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the back cover: step 12, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the back cover: step 12, image 3 of 3
    • Use the suction handle to lift and remove the back cover.
    • If the cover still feels stuck, go back around the perimeter with an opening pick and separate any remaining adhesive.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Check your rear cameras for any smudges and gently wipe them with a clean, lint–free cloth if necessary.
    • Your replacement back cover adhesive will be applied to either the frame or the back cover. Use cutouts and contours to see where it lines up best. If it matches the back cover, follow this guide. If it matches the frame, use this guide.
    Ask FixBot
  13. Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the wireless charging coil: step 13, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the wireless charging coil: step 13, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
    Ask FixBot
  14. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the wireless charging and loudspeaker screws: step 14, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the wireless charging and loudspeaker screws: step 14, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the wireless charging and loudspeaker screws: step 14, image 3 of 3
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    • Use a Phillips screwdriver to remove the ten screws securing the wireless charging and loudspeaker assembly:
    • Four 3.5 mm‑long screws securing the wireless charging coil
    • Six 3.5 mm‑long screws securing the loudspeaker
    Ask FixBot
  15. Samsung Galaxy S25 Ultra USB-C Board Replacement, Heat the wireless charging adhesive: step 15, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Heat the wireless charging adhesive: step 15, image 2 of 2
    • Two tabs on the right side of the wireless charging coil are secured with mild adhesive.
    • Heat an iOpener and lay it on the tabs for one minute to soften the adhesive.
    Ask FixBot
  16. Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tabs: step 16, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tabs: step 16, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tabs: step 16, image 3 of 3
    • During the next two steps, be very careful not to puncture or dent the battery, as it can leak dangerous chemicals or catch fire. Don’t use sharp or metal tools.
    • The tabs are very fragile. If it feels like they may tear, apply more heat and try again.
    • Gently slide the point of a spudger under the top edge of the upper tab and lift slowly to separate it.
    • You may need to do this a few times before the tab fully separates.
    Ask FixBot
  17. Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tape: step 17, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tape: step 17, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Detach the wireless charging coil tape: step 17, image 3 of 3
    • Repeat the previous step to separate the lower tab, starting at the bottom edge.
    Ask FixBot
  18. Samsung Galaxy S25 Ultra USB-C Board Replacement, Pry up the loudspeaker: step 18, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Pry up the loudspeaker: step 18, image 2 of 2
    • Use the point of a spudger to pry up the right side of the loudspeaker and unclip it.
    • During reassembly, press firmly around the perimeter of the loudspeaker to engage its clips.
    Ask FixBot
  19. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the wireless charging and loudspeaker assembly: step 19, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the wireless charging and loudspeaker assembly: step 19, image 2 of 2
    • Use two hands to remove the wireless charging and loudspeaker assembly.
    Ask FixBot
  20. Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the battery: step 20, image 2 of 2
    • Every press connector has a corresponding gold arrow on the board that shows the proper location to pry—nifty! Prying at the wrong location risks damaging the fragile surface‑mounted components on the board.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Ask FixBot
  21. Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the USB-C board: step 21, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the USB-C board: step 21, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Disconnect the USB-C board: step 21, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the two press connectors on the USB‑C board's top edge.
    Ask FixBot
  22. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the USB-C board screws: step 22, image 1 of 2 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the USB-C board screws: step 22, image 2 of 2
    • Use a Phillips screwdriver to remove the three 3.4 mm‑long screws securing the USB-C board.
    Ask FixBot
  23. Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the USB-C board: step 23, image 1 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the USB-C board: step 23, image 2 of 3 Samsung Galaxy S25 Ultra USB-C Board Replacement, Remove the USB-C board: step 23, image 3 of 3
    • Before trying to remove the board, make sure you've removed the SIM card tray.
    • Insert the point of a spudger in the gap under the top right corner of the USB-C board and gently lift until it unclips.
    • Remove the board, making sure the cables don't get snagged.
    • Make sure both cables that connect to the USB‑C board are out of the way—you may need to hold them up as you insert the board.
    • Insert the USB‑C board at a slight downward angle, guiding the port into its recess. Make sure the push connectors on the bottom edge are properly seated against the frame.
    • With the board in place, press down firmly on the center of the top edge to clip the board in place.
    • Be careful not to press on any small, surface‑mounted components.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
2 other people completed this guide.
Spencer Day
190,922 Reputation
1,204 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 78
Past 30 Days: 307
All Time: 961
