Google Pixel 9 Pro Front Facing Camera Replacement
  1. Google Pixel 9 Pro Front Facing Camera Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Ask FixBot
  2. Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. Google Pixel 9 Pro Front Facing Camera Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
    Ask FixBot
  4. Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    Ask FixBot
  5. Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: step 5, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: step 5, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Ask FixBot
  6. Google Pixel 9 Pro Front Facing Camera Replacement: step 6, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 6, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    Ask FixBot
  7. Google Pixel 9 Pro Front Facing Camera Replacement: step 7, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 7, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
    Ask FixBot
  8. Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: step 8, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: step 8, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    Ask FixBot
  9. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the wireless charging assembly: step 9, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the wireless charging assembly: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
    Ask FixBot
  10. Google Pixel 9 Pro Front Facing Camera Replacement: step 10, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 10, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement: step 10, image 3 of 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
    Ask FixBot
  11. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: step 11, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: step 11, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the rear cover: step 11, image 3 of 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
    Ask FixBot
  12. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
    Ask FixBot
  13. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the cable cover: step 13, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the cable cover: step 13, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
    Ask FixBot
  14. Google Pixel 9 Pro Front Facing Camera Replacement: step 14, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement: step 14, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
    Ask FixBot
  15. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: step 15, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: step 15, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the battery: step 15, image 3 of 3
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
    Ask FixBot
  16. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover screw: step 16, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover screw: step 16, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
    Ask FixBot
  17. Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: step 17, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: step 17, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Unclip the 5G mmWave cover: step 17, image 3 of 3
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
    Ask FixBot
  18. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover: step 18, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave cover: step 18, image 2 of 2
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
    Ask FixBot
  19. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: step 19, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: step 19, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
    Ask FixBot
  20. Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the front facing camera: step 20, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Disconnect the front facing camera: step 20, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
    Ask FixBot
  21. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: step 21, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: step 21, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna screw: step 21, image 3 of 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
    Ask FixBot
  22. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna: step 22, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the 5G mmWave antenna: step 22, image 2 of 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
    Ask FixBot
  23. Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: step 23, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: step 23, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Remove the front facing camera: step 23, image 3 of 3
    • Light adhesive secures the front facing camera in place.
    • Use the point of a spudger to lift the right edge of the front facing camera, separating its adhesive.
    • Use tweezers or your fingers to remove the camera.
    Ask FixBot
  24. Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: step 24, image 1 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: step 24, image 2 of 3 Google Pixel 9 Pro Front Facing Camera Replacement, Apply new front camera adhesive: step 24, image 3 of 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining blue liner from the adhesive.
    Ask FixBot
  25. Google Pixel 9 Pro Front Facing Camera Replacement, Install your replacement front camera: step 25, image 1 of 2 Google Pixel 9 Pro Front Facing Camera Replacement, Install your replacement front camera: step 25, image 2 of 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable on the right edge, press the front facing camera into its recess to secure it with the adhesive.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
190,922 Reputation
1,204 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
1 Guide Comment
Por favor me podrían indicar el nombre y número de referencia del ic que controla la cámara delantera, gracias
james patiño - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 105
All Time: 1,446
