Introduction
Use this guide to replace the rear cover adhesive in your Google Pixel 9 Pro.
Note: This guide should be followed during reassembly, after you've completed your repair and are about to reattach the rear cover.
Use a spudger to scrape up and remove all the old rear cover adhesive from the perimeter of the frame.
Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
Remove the larger clear liner from the rear cover adhesive.
Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
Grip the top right corner of the large blue liner with tweezers or your fingers and remove the liner.
Remove any liners from the underside of the rear cover, near the camera cutout area.
Apply a suction handle to the back of the rear cover, as close to the center of the right edge as possible.
Prop up the rear cover just to the right of your phone.
Reconnect the rear cover press connector to the logic board.
Lay the wireless charging assembly into place.
Use a Torx Plus 3IP screwdriver to install the five screws securing the wireless charging assembly:
Four 5.4 mm‑long screws
One 1.5 mm‑long screw
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Grip the left pull tab on the bottom edge of the frame and remove the blue liner from the left edge of your phone.
Lay the rear cover onto the frame and firmly press it into place.
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
3 other people completed this guide.
