Google Pixel 9 Pro Rear Cover Replacement
  1. Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Ask FixBot
  2. Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  3. Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
    Ask FixBot
  4. Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    Ask FixBot
  5. Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Ask FixBot
  6. Google Pixel 9 Pro Rear Cover Replacement: step 6, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 6, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    Ask FixBot
  7. Google Pixel 9 Pro Rear Cover Replacement: step 7, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 7, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
    Ask FixBot
  8. Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    Ask FixBot
  9. Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: step 9, image 1 of 2 Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
    Ask FixBot
  10. Google Pixel 9 Pro Rear Cover Replacement: step 10, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 10, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement: step 10, image 3 of 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
    Ask FixBot
  11. Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 1 of 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 2 of 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: step 11, image 3 of 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
    Ask FixBot
  12. Google Pixel 9 Pro Rear Cover Replacement, Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
    Ask FixBot
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
3 other people completed this guide.
Spencer Day
190,928 Reputation
1,204 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 95
Past 30 Days: 376
All Time: 7,480
