Introduction
Go to step 1 ↓Follow this guide to replace the screen and battery assembly on your Samsung Galaxy S24 Ultra.
This guide is written for the screen and battery assembly. The assembly consists of the screen, battery, and frame together in one part. Be sure you have the right part before you begin the repair.
If you just want to replace the battery, follow this guide.
If you just want to replace the screen, follow this guide.
Tools
Spudger4.9
Unplug any cables from your phone.
Hold the side key and the volume down button, then select "Power off" to turn off your phone.
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
Apply a suction handle to the back cover, as close to the center of the right edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the right edge to separate the adhesive.
Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the back cover for two minutes.
Insert a second opening pick next to the first one, near the bottom of the right edge.
Rotate the opening pick around the bottom right corner to separate the adhesive.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Insert a third opening pick next to the second one, near the left side of the bottom edge.
Rotate the opening pick around the bottom left corner to separate the adhesive.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Insert an opening pick in the gap at the top of the right edge.
Rotate the opening pick around the top right corner to separate the adhesive.
Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
Grab and remove the back cover.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
Four screws securing the wireless charging coil
Six screws securing the loudspeaker
Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
Pry up to unclip the loudspeaker from the frame.
Use a spudger to pry up and disconnect the battery press connector.
Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the daughterboard.
Use the point of a spudger to pry up the top left corner of the daughterboard.
Remove the daughterboard.
Use a spudger to pry up and disconnect the earpiece speaker press connector.
Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
Insert the pointed end of a spudger under the bottom edge of the earpiece speaker, under the engraved arrow.
Pry up with the spudger to unclip the speaker and remove it.
Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
Use a spudger to pry up and disconnect the lower antenna press connector from the motherboard.
Use a spudger to pry up and disconnect the stylus port press connector from the motherboard.
Use a spudger to pry up and disconnect the upper antenna press connector from the motherboard.
Use a spudger to pry up and disconnect the fingerprint scanner press connector from the motherboard.
Use a spudger to pry up and disconnect the front camera press connector from the motherboard.
Use a Phillips screwdriver to remove the two screws securing the motherboard:
One 4.0 mm-long screw to the left of the top camera.
One 3.5 mm-long screw to the left of the bottom camera.
Use your finger or a spudger to lift the top of the motherboard.
Remove the motherboard.
Use a Phillips driver to remove the two 2.5 mm‑long screws securing the lower antenna.
Insert one arm of a pair of angled tweezers or a SIM eject tool into the bottom screw hole on the lower antenna bracket.
Pry up and lift the antenna bracket out of its recess until you can grip it with your fingers.
Insert the flat end of a spudger under the upper antenna cable, between the antenna and the frame.
Twist the spudger to lift the antenna free of its adhesive.
Flip over the phone so the screen is facing up.
Heat an iOpener and apply it to the top edge of the screen for two minutes to loosen the front camera adhesive.
Flip the phone back over so the back of the front camera is accessible.
You're now left with the screen and battery assembly.
7 other people completed this guide.
