Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement
Views: 20K
View statistics:
Past 24 Hours:
47
Past 7 Days:
282
Past 30 Days:
1,188
All Time:
19,573
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the USB-C port and daughterboard in your Samsung Galaxy S24 Ultra.
The USB-C port is soldered to the daughterboard, so replacing either part requires replacing the entire assembly.
Tools
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the right adhesive: step 4, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: step 6, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: step 6, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom adhesive: step 6, image 3 of 3
      • Insert a second opening pick next to the first one, near the bottom of the right edge.
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    6. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 7, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 7, image 2 of 2
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the left edge: step 8, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    8. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: step 9, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: step 9, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the left adhesive: step 9, image 3 of 3
      • Insert a third opening pick next to the second one, near the left side of the bottom edge.
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    9. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 10, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 10, image 2 of 2
      • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
      • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
      • Leave the pick inserted near the power button to prevent the adhesive from resealing.
      Ask FixBot
    10. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Heat the top edge: step 11, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    11. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: step 12, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: step 12, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the top adhesive: step 12, image 3 of 3
      • Insert an opening pick in the gap at the top of the right edge.
      • Rotate the opening pick around the top right corner to separate the adhesive.
      Ask FixBot
    12. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 13, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 13, image 2 of 2
      • Slide the pick along the top edge to separate the adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
      Ask FixBot
    13. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: step 14, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: step 14, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the remaining adhesive: step 14, image 3 of 3
      • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the cameras.
      Ask FixBot
    14. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: step 15, image 2 of 2
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
      • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 2
      • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Four screws securing the wireless charging coil
      • Six screws securing the loudspeaker
      Ask FixBot
    3. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the coil adhesive: step 18, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Separate the coil adhesive: step 18, image 2 of 2
      • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
      Ask FixBot
    4. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 19, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 19, image 2 of 2
      • Use an opening pick to separate the tab from the frame.
      Ask FixBot
    5. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: step 20, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil and loudspeaker: step 20, image 2 of 2
      • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
      • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
      • Pry up to unclip the loudspeaker from the frame.
      Ask FixBot
    6. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 21, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 21, image 2 of 2
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: step 22, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: step 22, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: step 23, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: step 23, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Disconnect the interconnect cables: step 23, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 24, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 24, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement: step 24, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the interconnect cables: step 25, image 1 of 2 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the interconnect cables: step 25, image 2 of 2
      • Grab and remove the interconnect cables from the phone.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: step 26, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: step 26, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the SIM card tray: step 26, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
      • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
      • Remove the SIM card tray.
      • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard screws: step 27, image 1 of 1
      • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the daughterboard.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: step 28, image 1 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: step 28, image 2 of 3 Samsung Galaxy S24 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: step 28, image 3 of 3
      • Use the point of a spudger to pry up the top left corner of the daughterboard.
      • Don't pry against the battery. Angle your spudger to pry against the frame.
      • Remove the daughterboard.
      • During reassembly, reinsert the USB-C port into its recess at an angle before pressing the daughterboard flat onto the frame.
      Ask FixBot
13 other people completed this guide.
Spencer Pennington
27,749 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,178 Guides authored
4 Guide Comments
where can buy the charging port? And where can i get the glue to glue the back glass??
Randy Dicen - Reply Share
The glue is t7000 or b7000, can’t speak for the port though
Lowe Carlsson - Reply Share
I have the same issue as Randy.
The charging port has died. And Samsung wants to sell me a new one for 145.
And the local shop, says 90, but the port wont be original.
Sameer Quazi - Reply Share
Past 24 Hours: 47
Past 7 Days: 282
Past 30 Days: 1,188
All Time: 19,573
